Added seafoam for sticking lifter
Old Jun 26, 2013 | 04:46 PM
me 2's Avatar
Default Added seafoam for sticking lifter
I was told to add seafoam for a load sticking lifter. I added half the can and the rest to the gas. The lifter sounds louder now. Will it eventually clean up and quiet down or am I going about this the wrong way?
Old Jun 26, 2013 | 05:05 PM
me 2's Avatar
Default stuff
This is pretty much exactly the sound I have
Old Jun 26, 2013 | 05:29 PM
Mojigglins's Avatar
Are you 100% sure its a lifter? have you ruled out a slipped liner (with engine running taken off each spark plug and listen to see if the ticking stops)?
Old Jun 26, 2013 | 05:33 PM
Before you experiment any more on this, send me your number, my save you a fortune.
Old Jun 26, 2013 | 05:42 PM
FreeRideSLR's Avatar
Join the club. Mine has sounded like this for 3 years now. I remember Seafoam making it sound worse for a while as well. Sometimes the noise is really loud, sometimes it's soft, and sometimes it goes away for days only to return again. I've found there are lot's of theories with no real solutions.
Old Jun 26, 2013 | 06:09 PM
me 2's Avatar
Default stuff
I hope to god its not a slipped liner, that will make the second motor. I havent tried the plug thing yet.
Hey Mike, I spoke to you a couple weeks back already about this issue. I decided to bring it to a mechanic to see what he thought and he told me it was a sticky lifter.
How long does the seafoam usually take to do its thing? I could try a thicker oil next I suppose before I tear into the motor.
Old Jun 26, 2013 | 07:54 PM
Then don't try and cover it up with a bandaid. Are you mechanical enough to get into the top of the engine. Whatever is making that noise is failing and needs to be inspected.
Old Jun 26, 2013 | 08:55 PM
me 2's Avatar
Default stuff
Yeah, i have done a head job on this motor some time back. What do you suggest?
Old Jun 26, 2013 | 09:12 PM
First read my sticky at the top of this section on head gaskets and valve train noise, then call me, then tear into it.
Old Jun 26, 2013 | 10:00 PM
Lots of pix over in my thread on Head Gasket the Shade Tree Way....
