Adding Lights to Brushguard
you have blank switches where your fog light buttons are. get an etra cruise control switch from a junk yard or recycler here on the forum. run a relay under the hood. heat the switch from the igniton side of the fuse panel. wire the supply side of the relay from the battery and the corresponding side to the lights then your lights will turn on and off with the ignition. you need to use a cruise button because the light buttons require a latching relay. [IMG][/IMG] This is the relay i built for my lights.. It's very easy, but you gotta take your time and solder and heat shrink evrything
[IMG][/IMG]
[IMG][/IMG]
HE_CPT
10-26-2010 09:35 PM
red rockett
03-06-2008 02:53 AM
