Adding Lights to Brushguard
Old Sep 28, 2013 | 06:29 PM
jalodge's Avatar
Default Adding Lights to Brushguard
I am looking to add lights to the brush guard on my 2000 D2. How do I wire them to a switch on the dash?
Old Sep 28, 2013 | 07:57 PM
suzukisam967m's Avatar
you have blank switches where your fog light buttons are. get an etra cruise control switch from a junk yard or recycler here on the forum. run a relay under the hood. heat the switch from the igniton side of the fuse panel. wire the supply side of the relay from the battery and the corresponding side to the lights then your lights will turn on and off with the ignition. you need to use a cruise button because the light buttons require a latching relay. [IMG][/IMG] This is the relay i built for my lights.. It's very easy, but you gotta take your time and solder and heat shrink evrything
[IMG][/IMG]
Old Sep 29, 2013 | 01:01 PM
jalodge's Avatar
So if I order lights with a wiring harness, the only other thing I will need is a cruise control switch?
Old Sep 29, 2013 | 08:40 PM
yeah basically. it depends on what your lights come with. I made the wiring that was on my lights, it fits the truck exactly. you may want to trim the wiring to fit otherwise you might have a bunch of extra wiring you'll have to hide.
Old Sep 30, 2013 | 05:02 PM
jalodge's Avatar
I was looking at the KC SlimLight kit. It says it comes with pre-terminated wiring harness and relay.
TRIARII
Dec 18, 2013 04:16 AM
abran
Oct 1, 2013 09:09 PM
HE_CPT
Oct 26, 2010 09:35 PM
Daktari425
Aug 18, 2009 08:24 PM
red rockett
Mar 6, 2008 02:53 AM
