Adding oil cooler--questions about temperature and pressure
Old Jun 11, 2016 | 04:36 AM
chubbs878's Avatar
Originally Posted by neillr
Thanks abran, I probably will buy one of your kits. But what is the difference between the 2003/4 front cover and the 2002 and earlier? I can see that they're not the same, and it's got something to do with the oil cooler delete.
Don't worry about that, the covers are all the same. Many people have installed oil coolers directly to the 03/04 cover with no modification required.
Old Jun 13, 2016 | 10:26 PM
ATLDisco's Avatar
If this doesn't work, I put an aftermarket cooler on my 2003 with a sandwich adapter at the filter.
Been very happy with it, and the price/install was easy. I do everything I can to help the disco out here in the desert, 120F+ is hard on things with motors..
https://www.amazon.com/Rev9Power-Rev...S2F6P7AQM754Z9
Old Jul 21, 2019 | 05:24 PM
Discorama's Avatar
Thanks for the info that a 04 front cover will work when adding an oil cooler. The problem is that oil cooler lines are not available anymore and used ones are hard to get and might need replacing the hose. So I am going to make my own lines. Will M20x1.5 to AN adapters like these -> https://www.summitracing.com/parts/vpe-16628 work instead of the tube/nut on the front plate?
How to get these sealed? Here are my options:
1) 12mm crush washer in place of the O-ring.
2) 20mm crush washer on top of the cover
3) just teflon tape
4) combinations of the above
For the cooler I found 14mm compression fittings. To make them AN I found adapters in my local hardware store. The rest should be straight forward - metal braided hoses with AN ends.
Old Jul 28, 2019 | 12:41 AM
Discorama's Avatar
Finally I installed my oil cooler (stock connected at the front cover ports), but there is no flow. The cooler fittings are cold and I see no difference on oil temperature. Looks like the 04 front cover is really different and does not work with oil coolers.
Discorama
May 1, 2021 07:57 AM
Aj6543
Jun 24, 2018 09:56 PM
0304Disco
Apr 27, 2016 08:59 PM
cybercop
Apr 19, 2016 12:52 AM
abran
Sep 22, 2014 09:02 AM
