Adding SLS
Old Sep 29, 2008 | 09:28 PM
Aj6543's Avatar
Default Adding SLS
It is possible to add a self leveling system to a 2000 Discovery, if it doesn't have it installed. Im sure it would cost alot, right?
Old Sep 29, 2008 | 09:38 PM
Default RE: Adding SLS
Yes it would cost alot. And why would you want to add trouble?
But if yougo to www.atlanticbritish.com you can price the aircompressor, the air bags, almost everythingthat you need.
But you are looking at one million dollars!
Old Sep 29, 2008 | 11:20 PM
Disco2Guy's Avatar
Don't forget what the stealership will charge just to flip the "on" switch.
Old Sep 30, 2008 | 12:42 AM
Urban Panzer's Avatar
You could always get it all out of a scrap / wrecked / salvage vehicle, would not cost "that" much surely !!......would it ?and its not adding more trouble (ish) its adding another button to push ( I like buttons!!) and lots more flexibility.
Old Oct 1, 2008 | 02:31 PM
Willie 00D2's Avatar
If your just after extra load capacity you could get some aftermarket airbags that fit inside the springs.
Willie
Old Oct 1, 2008 | 04:08 PM
Or just get overload springs.
Old Oct 1, 2008 | 05:17 PM
Yes, ity could be done with a good used pump/control unit and 2 new airbags from Arnott.
Shout if you wqant to look further into this.
Old Jun 30, 2013 | 06:18 AM
frogger's Avatar
I don't know if you want to put in the original SLS system in as they are notoriously trouble some however I would be curious if you could use the slabs computer to control after marker air springs or air struts.
Old Jun 30, 2013 | 06:25 AM
If you look hard enough you will find other things on the Rover that need that time and treasure.
Old Jun 30, 2013 | 07:50 AM
Big Jim Swade's Avatar
Mine has SLS and it still is working good, but like the others have said, "why would you want to". It would be cheaper to sell the vehicle and buy a different one with it from the factory.
jalodge
Feb 22, 2014 06:15 PM
ninjaff21
Oct 29, 2013 01:06 AM
tee51397
Jan 20, 2008 10:12 PM
brunettc
Audio/Visual Electronics
Aug 8, 2005 07:31 AM
