Additional electrical hookup??
Old May 18, 2007 | 04:38 PM
Camdisco24's Avatar
Default Additional electrical hookup??
I need to find an additional electrical hookup somewhere under the hood. If anyone knows of one please let me know!!! I will let you know what the out come of this project is when ever I get done, but first I need to find a place to hook up the black and red wires!!
Old May 18, 2007 | 05:41 PM
Default RE: Additional electrical hookup??
What are you hooking up?
Look at the relay box behind the battery, plenty of placed to hook up.
Mike
Old May 18, 2007 | 06:05 PM
Camdisco24's Avatar
I am actually looking to hook up two wires (black and red) I dont see anywhere to hook them in the relay box but I might be missing something. Where to the lights get power from?
Old May 18, 2007 | 06:19 PM
The head light relays in that box.
Mike
Old May 18, 2007 | 06:46 PM
Camdisco24's Avatar
Do you know which one it is?? The directions say this: ground black wire to chassis body, connect red wire to a power source with a control switch (EX: parking light, head light, etc.) If you can help with that it would be great but since its not a regualr land rover thing you may not know!! THANKS
Old May 19, 2007 | 07:38 AM
Aquaholic's Avatar
How many amps will "it" pull? You may need to put a bigger fuse on the circut you choose.
You can connect the black to just about anything metal, do you have a test light or guage you can use to find the power source? Get a friend to turn the switch you want to use on and off until you find the appropriate connection. You can also listen to/touch the relays while they're switching and that will tell you which relay.
Old May 19, 2007 | 01:51 PM
Camdisco24's Avatar
Ok thanks, I will do that. I am putting on white LED windsheild Sprayers so its not something that is going to pull many amps. I saw them on a disco the other day and it just looked so cool, so I had to buy some for mine! I just figured it would be easy to hook the wires up somewhere but everything is harder to find than I thought. Thanks for the help!
Old May 21, 2007 | 07:51 AM
Rondo's Avatar
ORIGINAL: Camdisco24
Are you serious? White LED winshield washer nozzles? I hope they catch on fire.
Old May 21, 2007 | 08:36 AM
okdiscoguy's Avatar
ok, now I see why you didn't say right off what you were installing....
Tap into the parking lights wire. You may have to add wire and hook in by the headlights, but then just tuck it into a nearby loom.
I don't hope they catch fire, but......[sm=youreright.gif]
Good Luck
Old May 21, 2007 | 02:56 PM
Camdisco24's Avatar
ORIGINAL: Rondo
At the rate we are going, they probably will. But seriously they actually look really fantastic when they work, but I dont understand what everyone is saying to do. Sorry.
robersonb
Jan 11, 2013 09:09 PM
Cannonball55
Jul 21, 2012 10:17 PM
sanfranca
Sep 22, 2007 01:37 AM
ggushee
Sep 3, 2006 11:18 PM
charvey
Jun 25, 2005 03:11 PM
