Advice on tire set-up
Old Aug 16, 2009 | 12:13 PM
smokeyrabbit's Avatar
Originally Posted by Torancis_LR
... maybe I've been brain washed by all these good looking Disco's on this forum.
This is how the slippery slope gets started.
Old Aug 16, 2009 | 05:46 PM
Originally Posted by Disco_Fever
Rotating the spare with the others is not needed, but if you change the size on the ground it's best to have a spare to match (for obvious reasons). Plus, if you rotate all 5 tires you'll get 20% longer life/use from them before you have to buy tires again.
Leaving it on the back of the truck to "last forever" usually means it gets forgotten, dried out, low pressure, seized bolts, etc. If you rotate it through it's hitting the ground every 5k-6k miles and you eliminate the possibility of the aforementioned issues.
Just my .02
Read though this...
http://action.publicbroadcasting.net...t/1695610.page
The only way the spare is going to be significantly larger than the other 4 road tires is if you run them right down to the cords and then try installing your spare.
Even if the tire size was hugely different the open diff will compensate for it.
The diff will just think that you are turning a really long corner.
Now if you had a all wheel drive car then no, all four tires must be the same size otherwise you will burn out the clutches in the diffs and transfer case.
And as for caring for the spare tire...this is why your uncle Spike says to check the tire PSI and remove the lugs that hold it on and coat the threads with anti-seize every 6 months.
bagocheetohs
Aug 11, 2015 06:13 PM
Discolife
Nov 23, 2011 07:58 PM
nick731
Nov 16, 2010 12:25 PM
Brokenrover
Apr 2, 2010 05:19 PM
diego rover
Nov 7, 2007 04:22 PM
