multifunction relay?
Old Aug 16, 2009 | 10:11 AM
bowtiecb's Avatar
Default multifunction relay?
i know it controls the fuelpump, but what else is controled by the multi,i saw it somewhere, but cant find where i saw it. thanx
Old Aug 16, 2009 | 10:30 AM
Your fuel pump relay controls only the fuel pump, along with the fuse. Why do you ask?
Old Aug 16, 2009 | 06:10 PM
bowtiecb's Avatar
couple months ago i was have fuel problems,like the truck was running out of gas at 70mph or above sometimes. i replaced the fuel pump still did not work, then i cleaned the connection fired right up. but now its acting up again,just wanted to see by the name being multi, i thought it meant several,im going to trace the harness from the fuel pump back and check the connection. since you say the multi only controls the pump.thanx
Old Aug 16, 2009 | 06:12 PM
What year is the truck, if a D1, have you changed the fuel fulter?
Have you tested the fuel pressure when it stalls?
bleizit
Jun 24, 2020 04:03 AM
purplaze1972
Feb 25, 2014 08:48 PM
tiger1983
Mar 11, 2013 08:33 AM
Paladin
Feb 7, 2012 09:33 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
