Advise
Old Dec 17, 2021 | 10:10 PM
woodchip2bert's Avatar
Default Advise
Can I use the key option on my Disco11 to lock/unlock /start instead of the alarm [ alarm annoying goes off at inconvenient times]. or is it possible to immobilize the alarm completely
Last edited by woodchip2bert; Dec 18, 2021 at 03:28 AM. Reason: make addition wording
Old Dec 18, 2021 | 07:03 AM
mollusc's Avatar
The key works fine to lock, unlock, and start. I did not have a remote with my first truck for the first year that I owned it.
It will enable and disable the alarm though, so if you are having problems there, using the key may not solve the trouble you're having.
You may also want to change the door lock pin for an upgraded part before you rely exclusively on a mechanical locking process. The original pins have been known to fail. Carrs4x4 sells a good upgrade.
Old Dec 18, 2021 | 08:20 AM
H Hill's Avatar
Same situation as mollusc. My fob "died", basically disintegrated due to the age of the truck (280K), as well as the ignition switch replaced with a D1 version so I have new keys, so I use the old key for doors, and the new D1 key for the ignition. I have replaced the door pin with the one from Carrs4x4
. Works great!
MsCrystal
Nov 9, 2022 05:20 PM
dicksoutforharambe
Jul 11, 2021 01:02 PM
Alex Spencer
Mar 3, 2017 10:19 AM
Lacrosseboss18
Aug 26, 2010 04:07 PM
Vorhees
Sep 11, 2008 03:47 PM
