After headliner replacement, missing sun visor clip mount.
Old Jul 9, 2020 | 12:08 AM
Jason_B's Avatar
Default After headliner replacement, missing sun visor clip mount.
I recently took out the headliner card and had a shop put a new liner on it.
When re-assembling, the sun visor clips just sit in there loose and there is nothing for it to clip into. I turned the screw and it just wasn't grabbing on anything.
It seems like I am missing the metal plate on the inside that the clip clips to.
Does anyone know what part that is? Is there any way to secure these clips without that piece, I really don't want to unscrew the map holder and the handles to drop the liner if possible.
Thanks.
Old Jul 9, 2020 | 07:02 AM
coors's Avatar
Thanks.
I have my headliner out currently, I’ll snap a pic for you later today and see what I can find regarding the clips.
Old Jul 9, 2020 | 08:01 AM
coors's Avatar
Not much to it - just a square opening cut into the sheet metal. Double check the arms on the back of your clip aren’t compromised. If one has a crack or is damaged the arms won’t fully engage causing the clip to sit loosely in the sheet metal.
Old Jul 9, 2020 | 11:24 AM
Jason_B's Avatar
Originally Posted by coors
Not much to it - just a square opening cut into the sheet metal. Double check the arms on the back of your clip aren’t comprised. If one has a crack or is damaged the arms won’t fully engage causing the clip to sit loosely in the sheet metal.
thank you so much. I added sound insulation and I am sure it is blocking it. Nice to know it is in the sheet metal so I am not missing anything. I just need to dig the insulation away.
thanks again so much!
Old Jul 9, 2020 | 06:16 PM
Jason_B's Avatar
Hey thanks again. I got the clip in on one side and just need to do the other now.
I just had a bunch of soundproofing crap in the way. Also the new headliner pad was thicker than the old one so there was way too much padding.
I cut away some of the card-stock of the headliner, the soundproofing and compressed what was left with my thumb and got it to barley pop in. When I tightened the screw it held snug.
mr. choodles
Dec 16, 2017 07:22 PM
jalodge
Sep 22, 2013 12:12 PM
binvanna
Oct 11, 2012 10:05 AM
hhalimi
Mar 9, 2012 02:05 AM
Aj6543
Sep 19, 2009 03:44 PM
