Aftermarket coil pack?
Old Jan 28, 2016 | 09:45 AM
jamieb's Avatar
Default Aftermarket coil pack?
P0308 misfire on cylinder #8. Previously had a P0305 misfire on cylinder #5. Haven't seen #5 misfire in 2 weeks. Have had 1-2 #8 misfires in the last week. Ignition tester light shows weak spark in #8 wire.
1) I ordered new Kingsbourne 8mm wires to replace #5 and #8. The wires are only 3 months old.
2) To be safe, I was thinking of replacing the 1 coil pack that #5 and #8 are on. O'Reilly has a complete aftermarket coil pack for $63.
Import Direct Ignition 23-0134 - Ignition Coil | O'Reilly Auto Parts
They also have a single coil, Bosch for $71
Bosch 00136 - Ignition Coil (New) | O'Reilly Auto Parts
Anyone familiar with the aftermarket complete coil pack?
Thoughts?
Old Jan 28, 2016 | 09:53 AM
Alex_M's Avatar
While you're in there just replace them both. If one is bad, the other is going to go relatively soon. Unlike O2 sensors, the cheapest coils you can find on eBay actually work perfectly! I've been running a set for a little over 10k miles now with no issues. I'm sure the Import Direct will work just as well, but I think I paid in the ballpark of $40 each on eBay.
Old Jan 28, 2016 | 09:55 AM
Alex_M's Avatar
I'm sorry, make that $40 for the set. Here's the link. Ignition Coil Pair Set of 2 for Land Rover Discovery Range Rover | eBay
Old Jan 28, 2016 | 10:02 AM
jamieb's Avatar
Just ordered a set off eBay. Thanks!
Old Jan 28, 2016 | 10:13 AM
jamieb's Avatar
Anyone else get that bittersweet feeling after a trip to a place like Harbor Freight? Yesterday I got 2, 6-ton ramps, creeper, wobble socket extensions, flare wrench set, gear oil hand pump, safety glasses, gloves, ignition wire tester, flex head socket -- stuff to fix my ignition issue and brake job and fluid changes.
yay - new tools!
On the flip side - just dropped $180 on tools! LOL
Justifying by saying how much I'll save doing it myself. :-)
Old Jan 28, 2016 | 11:03 AM
Alex_M's Avatar
Haha, every time I go. But I do love new toys to play with. I need a chop saw and a new angle grinder next. Then I can start work on building a bumper and sliders.
Old Jan 28, 2016 | 11:34 AM
drowssap's Avatar
make sure you get the extended warranty on the angle grinder
Old Jan 28, 2016 | 11:44 AM
Alex_M's Avatar
Yea, I've had one of the cheap ones. Accidentally broke it myself, it wasn't even its fault, but I've heard they eat themselves. I've also heard the slightly more expensive red one is actually pretty solid.
Old Jan 28, 2016 | 11:46 AM
drowssap's Avatar
i burn up the red ones too, $10 esp and you just exchange for a new one
Old Jan 28, 2016 | 11:48 AM
Alex_M's Avatar
Good to know, I'll remember that for sure the next time I make it to HF.
