Aftermarket Starter Fun
Old Apr 23, 2014 | 10:08 AM
04duxlr's Avatar
Default Aftermarket Starter Fun
About 1 1/2 years ago, my '04 D2 began having problems starting. When you turned the key, nothing would happen. Then later when you tried to start it the engine would fire right up. I checked all the wires, tested the battery, etc. but found nothing so I had to wait until it failed to start again. The next time it did it, I was able to get the starter to turn by hitting it with a hammer. Of course it was at 7:30 on a Friday night, so I grabbed a starter from AZ for $91 and put it in. Everything worked fine until yesterday when I got a call from my wife who had the truck and my 2 kids on a little trip about 8 hours from home in Canada. "It won't start." "No problem, just get out the lug wrench, crawl under the car and hit the starter. Can't miss it, it's on the passenger side of the engine right where the transmission bolts on." "I see a rusty metal pipe, is it near that?" Oh boy. Ever try to describe a starter and where to find it to someone that isn't sure where the engine ends and the transmission starts? She actually did find it and got it to spin after one good whack. She called again this morning from a Friendly's parking lot to let me know she had to do it again. Another budding mechanic thanks to the magic of Land Rover! By the way, the starter is covered under a lifetime warranty. Very useful when it only lasts 25,000 miles. I guess I should have stuck with my initial plan of using the AZ one to get the truck running while I waited for a real starter to be delivered.
Old Apr 23, 2014 | 06:20 PM
I just pick up used ones the last a long damn time lol
Old Apr 23, 2014 | 07:05 PM
OffroadFrance's Avatar
Could be the starter relay or starter solenoid. It can also be bad earth connections or the spade connection on the starter solenoid. Unfortunately without a multimeter checkout it's a difficult one to nail.
Old Apr 23, 2014 | 07:17 PM
d7sec's Avatar
I still have a starter from AB for you, if you need one. $100, new, original packing.
https://landroverforums.com/forum/pr...r-parts-65606/
Old Apr 23, 2014 | 10:49 PM
04duxlr's Avatar
I just installed another one from AZ that I got under warranty. The spade connection and main cable were very tight and clean, and the earths were good also. My guess is it's just a crappy rebuild despite being "triple checked." Funny thing is, my wife wasn't too concerned about me fixing it right away. "It's no problem now that I know what to do" she said. I think she's discovering the true joys of Rover ownership!
Old Apr 24, 2014 | 04:59 AM
Sympathies, I'm going to tear out my Pajero starter today.........**** job.............bad access to bolts underneath (knuckle smasher).
I have the same issues............intermittent starting..................all the right 'clicks' seem to happen..................but often no action.................could be starter solenoid electrical contacts, motor brushes, or bad earth's somewhere. A real PITA.
Old Apr 24, 2014 | 08:56 AM
Ghaniba's Avatar
I get a bit nervous just driving mine over an hour from home!
Dave
Gimebakmybulits
Jul 14, 2014 05:57 PM
johnkbl
Apr 23, 2012 07:49 PM
thehaz
Jan 10, 2011 10:14 AM
diamondgeezer
Sights N Sounds
Aug 3, 2005 04:18 PM
05LandRover
Jun 8, 2005 09:31 PM
