Aftermarket Tie Rod ends - can't find
Old May 20, 2025 | 12:25 PM
Ethan_mikel's Avatar
Question Aftermarket Tie Rod ends - can't find
So when I bought the disco it had upgraded drag link and track link. Great. Well now the tie rod ends are going bad and Its time to replace them. But I can't find anything that matches these. They have an M20x1.5 shank, 147mm total length, as far as I can tell they fit into the original D2 knuckles and pitman arm (1/5 cone slope?). The Terrafirma heavy duty links use the OEM 11/16 size rod ends. Cant seem to find any other aftermarket options that match what I have. Anyone have any leads for where these may have come from, or places that sell aftermarket steering links that may use bigger rod ends? Pictures will be threaded soon
Old May 20, 2025 | 12:33 PM
Richard Gallant's Avatar
You are going to have a tough time without brand, but a lot of upgraded units used D1/Defender tie rod ends. You may have to replace everything
Old May 20, 2025 | 12:38 PM
Those seem to also be 11/16 shank. I'd really prefer to not replace everything. The links are pretty beefy and have performed well. Seems like any replacement would be a downgrade
Old May 20, 2025 | 03:54 PM
Harvlr's Avatar
They might be Britpart. I had the larger tie rods on my 2A.
Old May 20, 2025 | 08:29 PM
Brandon318's Avatar
I'd switch to Terrafirma bars so you can use Defender ends. Adjusting the Terrafirma bar is SO much easier if you ever need to adjust the straightness of your steering wheel. In general it's a substantial upgrade over the stock bar.
zuke
May 20, 2020 05:41 PM
TOM R
May 17, 2013 01:58 PM
MuleyJ
Aug 15, 2012 11:33 PM
collin Barrows
Jul 20, 2012 06:32 AM
ebg18t
Apr 25, 2012 08:18 PM
