Agressive and Quiet. looking for tires.
#33
And actually I didn't have to cut the front bumper at all, I have a Saudi Spec bumper which is "pre trimmed" from the factory for better clearance on the sand dunes of the Middle East and such. I just pulled the other lower bumper trim pieces temporarily to remove the factory brush bar/lights to make way for a winch tray.
#34
The only thing that needed to be trimmed with my 265/75's was the inner wheel well/splash guard piece on the passenger side. The tire would catch the edge on anything more than a 75% to full lock turn right or left. If you're wanting to try and squeeze in a slightly taller tire, I might suggest you consider some spacers up front to give you a little more room.
I have 16" rims that I can use, but my 18" rims are in better shape. It is about $200 more to run the 18" rime vs. the 16" rim.
#35
The difference is about 1/4" to 3/8" if I do the conversion right. I assume with the 2" lift that little bit of a difference won't warrant going to a 3" lift - will it?
As far as your rims go, I'd go with the 16's for the tire selection and then RATTLE CAN those thangs!...that's what I did! Rustoleum High Performance Wheel paint, then some clear coat.
Even did my Land Cruiser wheels rattle can style!
#36
To Piggy Back off the conversation I have a shot Steering stabalizer and am just going to overhaul the suspension in its entirety due to have 100K on it and feeling the sag. I am going with the OME medium and Nitro Charger shocks and want to run larger tires on the 18" rim, but am wondering what the largest i can go without rub? I don't want to go wider but taller as i like the more factory look of the slender tires.
Any help is appreciated
#37
Safe bet and good look is 275.
#38
I bought it. Quads went in with the Tru-Trac locker within a month.
In any case, they mostly wear when you spin one tire, is my
understanding. If you avoid wheelspin, no wear to speak of. Now axle
shafts are another story. I've broken 3 LR brand shafts on my Rangie so
far, included their HD rear shaft. 2 of those were pretty ugly repairs as
they broke within the splines. I'm now running all Ashcroft shafts on
the Rangie.
So, back to tires, 33s are as big as I would recommend unless you do all
that good axle stuff like pinning the carrier, Ashcroft shafts and CVs, truss/gusset, etc.
Then again, you're very unlikely to break anything if you run huge tires but
stay on the road. My pov is rather warped by my 4x4 trials competition brain.
#39
Please refer to my truck and sig. The 275/65/18 fills out the 2 inch lift pretty well. You could probably go up to 285/65/18 but you might need to trim some of the front bumper. Some here advise against 285/65/18 because of loss of power and the potential wear on the spider gears. But a few people have gone that big.
#40
Thanks for the info, I definitely do not want to trim anything if i do not have to, but need the extra clearance due to the last time i was out the pumpkin was the only part barely clearing the obstacles. I would go with stock replacement but it cost more in most cases than the OME.
You could also just spring for a diff guard???
