Air Compressor wont turn off
Old Apr 18, 2011 | 09:18 AM
jtherien53's Avatar
Default Air Compressor wont turn off
Driving yesterday my air compressor turned on and now it wont turn off. i have removed 3 of the larger connectors near the air compressor but it still wont turn off. what else is causing the air compressor to run, and in disabling the air compressor will i lose air in the rear air suspension?
Old Apr 18, 2011 | 09:21 AM
No, your a/c compressor has nothing to do with the SLS suspenion. How do you know your compressor is on? Have you turned it off at the dash?
Old Apr 18, 2011 | 09:23 AM
jtherien53's Avatar
its not the A/C compressor but the compressor for the SLS
Old Apr 18, 2011 | 09:26 AM
Have you checked for an air leak at the bags or air lines?
You can always pull the plug at the pump, that will turn it off but your suspension, if it has a leak , will then drop.
Old Apr 18, 2011 | 09:28 AM
jtherien53's Avatar
I have checked for a leak in the lines and the bags but everything seems to be good. i have disconnected 3 of the electrical connectors near the pump but its still running. is there another one on the back side?
Old Apr 18, 2011 | 09:31 AM
Send me your number and I'll call you.
Old Apr 18, 2011 | 10:31 AM
jtherien53's Avatar
thanks for the help Mike (Land Rover God).
Old Apr 29, 2011 | 06:39 PM
jjmelisa1's Avatar
Disco Mike, My rear end on my disco II is low. I have already checked sensors, lines, bags, the compressor comes on but only for about 45sec to a min then turns off. Any advise?
Old Apr 29, 2021 | 09:34 AM
4RoverLane's Avatar
3rd Gear
Default Same issue air compressor won't turn off. What was the solution
Same issue air compressor won't turn off. What was the solution?
Old Apr 29, 2021 | 10:32 AM
mollusc's Avatar
Pull relay #5 in the engine compartment fusebox, and then work out where your air leak is.
