air filter cover
Old Mar 15, 2008 | 02:29 PM
brw1982's Avatar
Default air filter cover
I was replacing my air filter, and when I unlatched the cover one of the latches snapped off (with very little force, so I'm guessing it was about to give anyway). I was wondering if this will effect anything, since it doesn't fit as snuggly now, and if I should replace the cover? I've looked on atlanticbritish.com and roverlandparts.com and have only found the air filter housing unit. So if I do need to replace the cover, I'd appreciate suggestions on where to find one...other than a dealership. The closest LR dealer is about 2-1/2 hours away.
Old Mar 15, 2008 | 02:33 PM
Default RE: air filter cover
I think you can only buy the lid with the box, I would call the closest dealer to make sure and if need be have them ship it to you.
Yes, if will cause problem for the MAF sensor if you run with a broken lid.
Southern Bawb
Apr 18, 2015 08:05 AM
hhalimi
Jan 29, 2012 11:43 AM
ragandhi
May 27, 2010 12:37 AM
Kswin
Apr 11, 2010 06:56 PM
