Air Into Cooling System?
Old 05-14-2015, 12:12 PM
robert.juric's Avatar
Originally Posted by Dave03S
Whatever the reason is, its the reason proper bleed procedures are not working.
That is probably true. Could it possibly be a leak in the heater core itself?
Old 05-14-2015, 12:17 PM
zeroone's Avatar
Been dealing with this since I replaced the HG in the beginning of January. It gets less and less each time. I'm not nit showing coolant anywhere, oil, ground, no over pressure in the system, pressure test shoes nothing. I never lose any real amount. I tend to keep the level at the he seem line. It has never fallen below the full mark. I'm guessing persistence is key. Just keep plugging away.
Old 05-14-2015, 03:53 PM
jamestfl's Avatar
hmph. sounds like you've really worked the problem. Have you checked all the hoses? I once had the hose that connects-up at the firewall ballooning when hot, then would let air in. didn't see it 'til like the 3rd or 4th time bleeding the system.
TRIARII
10-01-2014 07:43 AM
reddiscovery2
12-18-2012 08:54 PM
00&04 Disco
09-01-2010 04:46 PM
muellerny
02-28-2008 08:01 PM
Darover
06-12-2007 04:18 PM
Quick Reply: Air Into Cooling System?
