Air Into Cooling System?
Old May 14, 2015 | 12:12 PM
robert.juric's Avatar
Originally Posted by Dave03S
Whatever the reason is, its the reason proper bleed procedures are not working.
That is probably true. Could it possibly be a leak in the heater core itself?
Old May 14, 2015 | 12:17 PM
zeroone's Avatar
Been dealing with this since I replaced the HG in the beginning of January. It gets less and less each time. I'm not nit showing coolant anywhere, oil, ground, no over pressure in the system, pressure test shoes nothing. I never lose any real amount. I tend to keep the level at the he seem line. It has never fallen below the full mark. I'm guessing persistence is key. Just keep plugging away.
Old May 14, 2015 | 03:53 PM
jamestfl's Avatar
hmph. sounds like you've really worked the problem. Have you checked all the hoses? I once had the hose that connects-up at the firewall ballooning when hot, then would let air in. didn't see it 'til like the 3rd or 4th time bleeding the system.
TRIARII
Oct 1, 2014 07:43 AM
reddiscovery2
Dec 18, 2012 08:54 PM
00&04 Disco
Sep 1, 2010 04:46 PM
muellerny
Feb 28, 2008 08:01 PM
Darover
Jun 12, 2007 04:18 PM
