Air conditioning system off and blows heated air
Old Dec 18, 2012 | 12:56 PM
reddiscovery2's Avatar
6th Gear
Default Air conditioning system off and blows heated air
While I'm driving with the Air conditioning system off the vents blow heated air. Why?
Old Dec 18, 2012 | 01:18 PM
jafir's Avatar
Late model D1 and all the D2 always circulate coolant through the heater core. If the doors don't close all the way in the blower box, a lot of heat will leak through. Something might need adjusted or repaired, but try turning the temp all the way down to LO on both controls before turning off the climate control and see if that helps.
Old Dec 18, 2012 | 01:56 PM
lr2001silver's Avatar
Banned
We all have this issue! Just crack the window and smile its a disco thing!
Old Dec 18, 2012 | 02:55 PM
I have also found that if you run the a/c first for a minute the hot air will be less noticiable.
CANAMDiscovery's Avatar
Same issue...not like it is BLOWING hot air, but it comes through the vents.
I live with it and understand how the heater core continues to circulate, but I wonder if the Discoverys right out of the factory did this?
Is there is something in the system... a "flap" that does not close 100% in the dash after the LR ages.
If I wanted this issue resolved, could it?
Old Dec 18, 2012 | 02:58 PM
Yes, they all do it. Way back when people started complaining about it Rover switched a number of parts including the control panel, didn't fix a thing.
Old Dec 18, 2012 | 08:45 PM
Shade Tree's Avatar
Disco Mike, This problem sounds like something that will be an issue for me in about 4 months. Can I put a shut off valve in the heater core supply line and close off or regulate the hot water supply when not needed? Would this cause any big problems with the cooling system flow?
Thanks for you thoughts.
P.S. Working through your high mileage maintenance list.
Old Dec 18, 2012 | 08:51 PM
Heater cores are frquently bypassed in very warm areas. Make sure you arrange valve to bridge the unit, rather than just dead ending.
Old Dec 18, 2012 | 08:54 PM
Shade Tree's Avatar
Thanks!!
2001_Disco
Dec 10, 2014 01:36 PM
zski128
May 30, 2013 06:38 PM
mpompliano
Freelander
Jul 31, 2012 06:13 PM
chiperio
Jul 24, 2011 11:41 PM
