Air Suspension to Coil Conversion / Wheel size Questions.
I have a 04’ D2 HSE that I purchased a few weeks ago. I have searched this forum and found answers to MANY of my questions as an new D2 owner. I have 2 questions pertaining to my next mod;
#1. I plan on adding a 2” Terrafirma Lift kit, from Lucky 8, and converting my Air Suspension over to Coil.
- Is this the right move?
- Any problems doing this?
- What is to removing the air suspension?
- I have seen where someone had to have there vehicle re-programmed because they removed the air suspension. Will I also have to do this?
#2. I plan on replacing the stock 18” wheels with 16” Vision 168 AutoBahn Wheels. I will be raping these now wheels with Cooper Discovery AT3 265/75/16.
- My main question is will these rims fit without having to replace the calibers or brake rotors?
I greatly appreciate any help!
Donnie
Donnie
![Driving](https://landroverforums.com/forum/images/smilies/driving.gif)
A few of my buddies removed the air suspension and replaced with coils. I lent my Nanocom to them. Just did the latest unit a couple of weeks ago. It was a quick programming change on the Nanocom to change the air suspension setting from ON to OFF. You can direct the Nanocom to "write" (upload) the new setting to the ECU/BCU. Re-start the engine and the air suspension error light disappeared.
b_woodroaster
11-05-2010 08:54 AM
Spensive
03-19-2010 06:36 AM
mtfinchrr
01-24-2009 07:44 PM
