air suspension ECU
Old Dec 10, 2010 | 03:22 PM
rphotographer's Avatar
Default air suspension ECU
My disco is in the shop and they tell me I have a faulty ECU for the air suspension,
they hook up their auto-logic computer to the car and everything works fine, pump, bags inflate etc, when the computer is taken off the car, the rear end goes back down.
they want to charge me and arm and a leg for this ECU unit, can i put a used one on?, if so where is this unit located and do I have to have it hooked to the auto-logic computer again?
My question is, can I put this unit on myself or doe the shop need to do this??/
any advise is grateful!!!
Thanks
Ralph
Old Dec 11, 2010 | 08:53 AM
Do nothing and send me your number, I'll call you today.
Old Dec 18, 2010 | 11:25 AM
Default air pump
Hello Mike,
as per our conversation, I pulled the positive lead off the battery, waited 20 seconds, replaced the lead, closed all the doors, started the truck, did not lift, and the light on the dash ( rear end of disco with arrows pointing up and down) is now blinking.
what should I do next?
Thanks
Ralph
Old Dec 19, 2010 | 03:54 PM
Rovin4life's Avatar
its probably a fair bet something isn't telling the vehicle to stay up. If the ecu was bad it would be sending a signal to valve body to let the air out of the rear. If it were me, I would get the vehicle up and then disconnect the connector on the valve body to see if it falls or not. if it does, the ecu isn't the problem.
of course you can always just put in coils and get it overwith.
Old Dec 31, 2010 | 11:11 AM
OhioDisco's Avatar
A quick note for anyone else who might review this thread. Make sure you check the 30 amp fuse link in the fuse box under the hood. The owner's manual doesn't call this out, but the RAVE manual does. That was the issue with mine and it was a $4 fix. It's the FL in the middle of the row of links, and although the part at Advance Auto wasn't identical, it does work.
Old Jan 2, 2011 | 09:27 AM
Picko's Avatar
3rd Gear
this one?
This reset process is in the owners manual and Rave CD.
with the key in the ignition and front door closed
open drivers door
pull key out of ignition and wait (count to 10)
then put key back
close drivers door
restart car,
Worked for me one morning, no probs since
Cheers
TRIARII
Jun 30, 2022 09:48 AM
Paul Grant
Aug 10, 2014 12:29 PM
fastrx7man
Jan 28, 2012 12:49 PM
