air suspention not lifting
Old Jan 30, 2012 | 03:46 PM
markham's Avatar
Default air suspention not lifting
just bought my 02 disco it had a bad compressor ,changed it out every thing worked fine except realized right rear bag had slow leak when parked .
today got in it to take a 200 mile trip and the pump only gos for 5 sec and shuts off ,,not enough air to lift to correct hight.. all doors are closed car running .. pushed the raise hight button on dash it flashes but pump does not come on...any sugestions
Old Jan 30, 2012 | 05:16 PM
tee51397's Avatar
Check fuses and try swapping out the relay for a like one to troubleshoot the easy things. Also, depending on how low that bag was the pump could have timed out. Really, first step is to find and fix the leak.
Old Jan 30, 2012 | 08:07 PM
Stop pushing the dash button till you find out what it is and when it can be used.
Send me your number and I'll walk you thru what to do.
JBCO
May 24, 2015 12:12 PM
skrewyluie
Dec 8, 2011 05:46 PM
xb70valkarye
May 9, 2007 06:56 PM
trailhead4x4
Mar 11, 2006 07:45 PM
hotchicken
Apr 3, 2005 07:04 PM
