Airbox Lid Clip Fix
Old Jan 17, 2015 | 08:45 AM
Colorado David's Avatar
I might be inclined to use machine screws with nyloc nuts instead of threading into the plastic.
Old Jan 17, 2015 | 10:04 AM
bmeier's Avatar
My tab broke the other day, good idea, I'm going to do that later today.
Old Jan 17, 2015 | 04:48 PM
bcolins's Avatar
Default Got it done this afternoon. Easy Peasy
Works as well as the original clips. Couldnt find my Dremel,...so ended up using my 4" angle grinder to remove the excess old clip mounts. A bit of hand filing,....and,....I had slight gaps around the O-ring in the two areas where the old clips tore away from the lid. All Good now. Thanks for the great tip Madlands
One caution. The new inboard clip/hasp is very nearly touching the radiator overflow coolant recovery line. It's still the original black plastic tubing,....which....if you have ever tried to remove any of the black plastic tubing,.....you know,...it just breaks. It is VERY brittle.
I would recommend rotating the MAF a bit so that the inboard clip point is lower/well clear of the radiator coolant recovery black plastic line. That will make the outboard clip/hasp a bit higher than it originally was,....but that should not be an issue in any way.
Old Jan 17, 2015 | 11:10 PM
Madlands's Avatar
Glad I could be of some help. I hope it continues to work for you. You are right about the clip being close to the coolant line and your idea to rotate the MAF sounds like it could work pretty well. I replaced the radiator not too long before doing this and swapped the lines to all rubber hose so I wasn't taking the lines being brittle into consideration.
Old Jul 4, 2015 | 06:27 PM
chubbs878's Avatar
I just went to Lowes and picked up a set of these. Thanks for the info and write-up!
Old Sep 1, 2018 | 12:07 AM
Akiben's Avatar
5th Gear
I know this is an old post, but you saved me ~$150 tonight.
Roflcopter
Jun 21, 2014 05:08 PM
TRIARII
May 29, 2014 09:04 PM
keoni004
Mar 4, 2013 06:10 PM
ColoDisco
Sep 29, 2010 11:51 AM
ColoDisco
Sep 7, 2010 11:29 PM
