Alarm light blinking,wont start
Had some body work done to my truck and when I went to pick it up they said they couldnt get it started,it looks like the alarm is on but I cant get it to disarm.I have never had a problem disarming it,now my truck is stuck at the body shop and I am stuck with a Hyaundai Sonata(rental).
Any suggestions?
Any suggestions?
When I hit the remote the yellow lights on side blink and i can hear a clicking noise from the dash but when I tried to start the truck the only thing that happens is all the warning lights come on .
rear drivers side door was dented so they fixed dent painted the door and rear quarter panel.I dont remember if it was locking and unlocking the doors tonight but it usually does lock and unlock the doors,when I turned the key in the door it locked and unlocked the doors.
I know you posted the challenge with your disco not being able to start and the alarm stuck on two years ago, but did you figure out how to fix it? I am having the same problem. Kindly, Jacob cu42dk@gmail.com
cu42dk same problem
Let me know if you find out anything. Same problem.
Replace the battery in your key fob? Disconnect the main battery in your Disco and put it on the battery charger for a few hours on a regular charge, reconnect and see what happens.
The other thing that can happen is if the emergency fuel switch gets tripped then the hazard lights will flash, the dash light will come on but nothing will happen when you try to turn it over.
If all the body shop did was work on a rear door then the fuel switch is not likely the issue as it needs to be hung upside down for it to trip so this would mean it was removed from the firewall in the engine bay and left to hang or your Disco got turned upside down!
Make sure all "5" doors are fully unlocked.
My rear passenger side door mechanism is starting to go and is very slow damn near almost unresponsive when I press the unlock button on the key fob. Sometimes I have to hit the unlock button twice to "fully" unlock the door so the light stops blinking on the dash thus allowing me to start the engine.
dofbft
Aug 15, 2013 11:52 AM
OMAR
Mar 16, 2005 12:46 AM
