alarm light on dash; can't start vehicle
Old Dec 9, 2008 | 08:38 PM
kritter's Avatar
4th Gear
Default alarm light on dash; can't start vehicle
2002 land rover discovery, 45k, alarm light on dash blinks continuously and rapidly. cannot be turned off using reasonable techniques. vehicle will not start. help!?
Old Dec 9, 2008 | 08:42 PM
Default RE: alarm light on dash; can't start vehicle
Sounds like it was "super locked". That is a extra security feature that disables everything.
Sorry, but I do not know how to dis able it.
Have you tried unhooking the battery for 30 mins or so?
Old Dec 9, 2008 | 08:46 PM
kritter's Avatar
4th Gear
original description incorrect. Alarm does go on and off. When I try to start the car the engine makes that sound like the battery is dead and THEN the alarm goes off? any ideas. battery is just dead?
Old Dec 9, 2008 | 09:04 PM
kritter's Avatar
4th Gear
Old Dec 9, 2008 | 09:25 PM
Will it turn over at all? Or do you get nothing when you try and start it?
When you say the alarm goes off, do you mean it shuts off or it "go's" off? (horn honks, lights flash)
Old Dec 9, 2008 | 09:31 PM
kritter's Avatar
4th Gear
I get nothing. The lights on the dash come on as i turn the key but then there is a churning noise and then the alarm honks, blinks, etc. I can turn on interior/exterior lights, fan, radio..... but car will not start and when encouraged to do so (i.e. turning key) the alarm honks, etc.
Old Dec 9, 2008 | 09:40 PM
Willie 00D2's Avatar
Are the head lights dim. I could be a dead battery.
Willie
Old Dec 9, 2008 | 09:42 PM
Ok, sorry, I am out, I've got nothing more to try and help you, sorry.
Best of luck to you.
Old Dec 9, 2008 | 10:22 PM
AK Rover's Avatar
It sounds like the battery needs to be replaced. When you try to start you're pulling what little charge the battery has and confusing the alarm. If the alarm's starter disable was causing the problem you would get nothing when you turn the key to the start position. From my understanding of your description the starter is trying to engage but not getting enough power from the battery.
MsCrystal
Nov 9, 2022 05:20 PM
gavone1976
Apr 4, 2014 08:45 AM
TexasDiscovery
Aug 6, 2013 12:54 PM
jvargas12g
Jul 21, 2012 10:43 PM
Rovinfool
Sep 7, 2010 12:30 PM
