alarming immobiliser or immobilising alarm
Old Apr 13, 2022 | 10:40 AM
discollama's Avatar
Exclamation alarming immobiliser or immobilising alarm
hi folks, i have a 04 disco 2 td5, now the bad news lol, fob doesn't and never has worked since i have it, so i lock and unlock with key, drivers door and all others open no problems there.
A few months back the key would not turn in the lock and to make a long story short the key was snapped in half in the lock, the two halves of the key would work the lock no problem.
But recently now if i lock and unlock the door, the alarm will activate when i open the door and it wont start, fuel pump running all lights and wont even turn over. put nanocom on it and it has no faults but wont connect to bcu at all,
if i leave positive disconnected over night it will start with red light flashing every 2 seconds and alarm will activate (horns disconnected), once i lock and unlock it it wont start, unless I disconnecting battery for hours again. if i drive like this alarm eventually gives up, but wont start up again after locking door. I have repaired door lock so fob/plip key can be used now.
i have tried to use eka codes with fob key but just get single beep each time so not sure whats going on there, have original code on manual, any ideas guys tia
can i disable the alarm and immobiliser completely?
should i replace the bcu?
Mike1
Mar 8, 2022 05:45 PM
elimaesner
Discovery Sport
Sep 25, 2018 11:07 PM
ara25
Mar 8, 2011 06:52 AM
bsmullinax
Jan 21, 2009 06:39 AM
