All Aluminum Coolant Tank
Old Jan 3, 2018 | 04:57 PM
Lisa Bunch's Avatar
Default All Aluminum Coolant Tank
Has anyone tried this?
I hope it shows the picture...
Old Jan 3, 2018 | 05:53 PM
Sixpack577's Avatar
How much is it?
Old Jan 3, 2018 | 06:16 PM
Alex_M's Avatar
Not seeing a picture. I removed my coolant tank all together and upgraded my radiator. I plan to make a post with more details in a few days. Not a full write up, but enough to get someone plenty more than started.
Edit: nevermind. Picture loaded the second time.
Old Jan 3, 2018 | 06:39 PM
Looks promising Lisa
Old Jan 3, 2018 | 06:47 PM
Dave03S's Avatar
does it have a sight tube so you can see the level?
Old Jan 3, 2018 | 06:53 PM
Lisa Bunch's Avatar
I don't think it has a sight tube, you remove the billet cap (sold separately) and look down the fill neck.
A good tank is $50, which is 2 piece plastic. For $70 more, I could try this.
Old Jan 3, 2018 | 08:52 PM
Best4x4's Avatar
Not LR Specific? Does it have the larger hose outlet on the bottom? It looks like it could work, but I like being able to see my coolant level. One thing I disliked with my OEM D1 coolant reservoir.
Old Jan 3, 2018 | 09:09 PM
OverRover's Avatar
If you want a tank that is DII specific/with a site glass then it's a Allisport AS202.
It's Pretty BUUUUUUT SPENDY!!!!!!!!!!
> https://www.allisport.com/shop/perfo...8-header-tank/
Old Jan 3, 2018 | 09:25 PM
OverRover's Avatar
That MOROSO Tank (#63768) is designed to fit a Ford Mustang '05- '10.
So I guess find the diameter of the bottom hose for the Mustang tank and it just might work.
LET THE GAMES BEGIN!!!!
Old Jan 3, 2018 | 09:48 PM
Alex_M's Avatar
Lisa, I went ahead and posted up my post about my setup. Quite a bit more involved than just replacing the tank, but not much more expensive and addresses a lot more issues with the factory system.
