All Indicator Lights On
Old Mar 6, 2011 | 01:01 PM
ctk111's Avatar
Default All Indicator Lights On
Truck had been sitting a few days. Go for a drive and then after reaching destination I exit the car and try to lock the doors with the key remote, but it won't work. I get in car and use the electronic locks on the dash and they work fine. I try remote key locks again and still don't work. I manually lock the car and then go in to the store.
When I start the truck back up the transmission indicator is flashing and will not indicate which gear the truck is in. The truck drives fine. However, I noticed the turn signals no longer work as well as the rear windshield wiper. The lights work and the front windshield wipers work as well. When I got home and shut off the car all the dash indicator lights stayed on. Has anyone seen this before? Thanks in advance.
Chad
Old Mar 6, 2011 | 02:35 PM
GARovee's Avatar
Check your battery voltage and make sure the system is charging. Sounds like the alt may be the issue. Just a thought.
Old Mar 6, 2011 | 03:30 PM
ctk111's Avatar
After letting the car sit for a couple hours I went outside to check on it and all the indicator lights are now off and everything seems to be working correctly. Thanks for your suggestion. I'll get the alternator checked to see if this might be the cause of the issue.
Old Mar 6, 2011 | 09:25 PM
coors's Avatar
Agreed. Sounds like your alternator.
honda50r
May 19, 2020 06:51 AM
iplayblues4u@comcast.net
Oct 13, 2009 02:13 PM
txbdq
Aug 18, 2009 11:30 AM
SherryG
Dec 20, 2007 01:48 PM
