Altantic British Motors
Old Feb 25, 2014 | 11:42 AM
T.J.'s Avatar
"Run outside the truck, if it says Discovery 2 on the back, it probably has slipped liners".
-- Too funny.
Old Feb 25, 2014 | 01:39 PM
Dan7's Avatar
$6K says mine doesn't
...anymore that is.
Old Feb 25, 2014 | 02:08 PM
MarkSF's Avatar
Discussion forums do tend to impart the feeling that EVERY single vehicle of a particular model will develop a particular fault.
Now, if I look on Craigslist, I can see many Discovery IIs for sale, with up to 150K miles. It would therefore be reasonable to conclude that those vehicles spent a considerable proportion of those miles without blown head gaskets.
Old Feb 25, 2014 | 07:23 PM
primussucks's Avatar
Originally Posted by Dan7
Your assumption of getting another 100K mi out of that engine with head gaskets and regular maintenance is a stretch.
what draws you to this conclusion?
i have 133k on original block, heads, etc. and that is the bad design.
if you get a complete new block, why would think you could not get 100k out of it?
Old Feb 25, 2014 | 08:26 PM
Dan7's Avatar
Slipped sleeves, lifters, cam, oil pump, another HG job, RMS, etc...these are all high dollar/labor jobs that are not unlikely to be needed in under 100K mi even with proper maintenance. There are certainly examples of engines which beat the odds. I wish I were wrong, but frankly, that's why this forum is so vital!
Old Feb 26, 2014 | 11:59 AM
borchera's Avatar
X2 - 141K miles on our original head gaskets and block.
The cooling system has to monitored and repairs made immediately. If you are losing coolant STOP driving your rover until you figure the problem. We check the coolant and oil once a week.
Another suggestion is the water pump replacement should also included the viscous fan. All the plastic coolant lines/ parts should be replace if you have over 100K miles as I just touched them to replace the battery the plastic lines were as brittle as an icicle.
2003 Discovery 141K
Yoops Racing
Aug 8, 2018 11:19 AM
Corrigan
Apr 26, 2013 02:38 PM
s10lowrider1994
Sep 29, 2011 03:08 PM
pdv83
Nov 20, 2007 12:34 PM
Oldracer
Nov 11, 2006 09:54 AM
