Alternative to bora
Old May 20, 2019 | 02:31 PM
escott16's Avatar
Default Alternative to bora
Is there any cheaper alternative to bora spacers? I obviously will not buy cheap Chinese 30$ ones off amazon I was wondering if there are any other reputable ones available thay aren’t almost 300$. Would a Chevy with the same bolt pattern spacers work? I believe it’s 5x4.75
Old May 20, 2019 | 03:00 PM
Alex_M's Avatar
No, Chevy spacers will not work. They must be hub-centric. Terrafirma makes them, but they are most likely Chinese - I wouldn't use them. There's another reputable company I've heard of making them as well. Spidertrax? I can't recall off hand. They will be expensive as well, however.
Essentially, not really.
Old May 20, 2019 | 03:09 PM
OverRover's Avatar
Or grab a set of 4 from across The Pond ( shipping will add about $15- $20 ).
> https://rimmerbros.com/Item--i-RD1294TF
Old May 21, 2019 | 07:52 AM
redwhitekat's Avatar
Are these safe to use ?
Old May 21, 2019 | 10:14 AM
Richard Gallant's Avatar
@redwhitekat generally they are. The problem is people go really big on spacers and add very large heavy tires, well beyond what the rest of the system was designed for. Eventually something breaks,usually bearings.
It is a solution if you use some common sense.
If you what some basics Wheel spacers
Old May 21, 2019 | 10:36 AM
escott16's Avatar
I’m on a 2” lift with 32” and generally do no wheeling so I don’t need the best of the best
Old May 21, 2019 | 10:46 AM
I know here in Canada Ontario they are cracking down on tires that stick out past the fenders
Old May 21, 2019 | 11:05 AM
escott16's Avatar
Mine are just tucked, wanting a more aggressive stance without being too wide. Where I live they don’t care. These tires are brand new and I only put under 5k miles a year on it so swapping for smaller wheels with a different offset isn’t an option right now
Old May 21, 2019 | 12:07 PM
Alex_M's Avatar
Tire weight and size has nearly nothing to do with stress in the spacers. The maximum I would comfortably go on a wheel spacers is 1.25", I may stretch to 1.5" in a strictly road use situation. I have 1.25" BORA spacers on my Silverado.
Buy the best or don't buy any. This is one of the most vital parts of your vehicle. If a wheel comes off going down the road you could easily enter a rollover situation, or careen into oncoming traffic. 9 times out of 10 if a spacer breaks it will be one on the front of the vehicle because that's where they are under the most stress.
Please, if you buy spacers just bite the bullet and get the best. I'm a big proponent of pinching every penny, but not where it may cause a serious safety issue.
Old May 22, 2019 | 02:39 AM
JUKE179r's Avatar
Georgia was bad for this too.
