Alternator? Fuse? Electrical?
Old Dec 7, 2007 | 09:59 AM
pdxdisco2's Avatar
4th Gear
Default Alternator? Fuse? Electrical?
1999 Disco II - 115K orig owner
Question to y'all:
Right after a cold start or a start after enging not running for a while...dash lights and head lights are dimmer than usual. Once you drive about a block or get the engine to rev up higher than 3K...the dash lights and headlights turn to normal brightness.
Noticing a slow drain on the battery. Obviously it is looking like that the alternator is not getting a consistent charge. Just want to confirm this with anyone's similar experience. Want to make sure that it is not a fuse or anything wierd. Pls confirm similar incidents b/c it looks like the alernator is on its 9th life. Thanks!!!
Old Dec 7, 2007 | 10:12 AM
Default RE: Alternator? Fuse? Electrical?
I would suggest you go to some place like Auto Zone, where they do free battery and alternator test, and have them perform a load test to see what is going on. Before doing this, check, clean and tighten your battery and alternator connections.
Let us know how it turns out.
Blakesrover
Feb 21, 2013 01:43 AM
DiscoStuart
Dec 23, 2011 08:32 AM
mgabriel
Dec 11, 2008 11:53 PM
SurfingRover
Dec 6, 2007 06:22 PM
socrazy2992
Sep 14, 2005 06:06 PM
