Alternator negative broke….any way to fix
Old May 13, 2022 | 04:39 PM
kgov's Avatar
Default Alternator negative broke….any way to fix
I started to dig into my front cover to do the oil pump and when trying to get the negative cable off the alternator it broke. Any way to fix it or am I hosed?
Old May 13, 2022 | 05:08 PM
Harvlr's Avatar
I think it’s a positive cable as the negative will be a case ground. Maybe someone here knows a fix but I think you’ll be needing a replacement alternator.
Old May 14, 2022 | 10:20 AM
frostythor's Avatar
Old May 14, 2022 | 02:07 PM
Xanthro's Avatar
It can be fixed for around $100 and you'll have to remove the alternator, fix it, then replace it. There isn't a safe way to fix your existing one.
Or, you could just buy a new higher performance alternator, which is what I'd suggest, since it's actually less work, and rebuilt one (if money is an issue) is only about 50% more cost than. you trying to fix your existing one, and it is less time consuming.
My original alternator literally failed because the same piece broke connection while driving, so yours may have already been damaged.
Old May 15, 2022 | 06:57 AM
lippmoney's Avatar
I wouldn't say you're hosed. Screwed is more like it.
Same thing happened to me during the replacement of a worn out alternator, thankfully. My solution was staring me in the face.
Old May 15, 2022 | 09:32 AM
cvhyatt's Avatar
You can buy a used alternator off eBay for ~$80. Or you can buy a newer one for $180. I ended up going with the latter.
LActrical ALTERNATOR FOR LAND...
Amazon Amazon
Old May 15, 2022 | 12:11 PM
disco96sd's Avatar
I got a Land Rover original that was rebuilt with 1 year warranty for $100 - that is my suggestion
Old May 15, 2022 | 05:13 PM
jastutte's Avatar
from where?
Lando123
Sep 25, 2021 05:26 AM
disco-disco
Oct 14, 2017 01:08 PM
humroot
Apr 20, 2011 09:32 PM
JumPeR04
Dec 17, 2009 07:57 PM
lennie5936
Jan 2, 2009 09:42 AM
