Alternator Question
Old Jul 28, 2013 | 06:10 PM
ProRiderRoadKing's Avatar
Lightbulb Alternator Question
After doing some more testing in search of my parasitic battery drain, I'm pretty sure that my alternator is the cause and I have a couple of questions.
I put my multimeter between the alternator connection on the fuse block and the charging lead from the alternator, and it showed a 130ma drain; this is with the alternator mounted. When I remove the alternator from it's mount the multimeter shows no drain.
Am I correct in my understanding that there should be no drain whether or not the alternator is mounted, and this is indicative of something inside the alternator, probably a bad diode, grounding out and causing the drain?
Old Jul 28, 2013 | 06:42 PM
When you removed it from the mount you broke the ground connection.
Old Jul 28, 2013 | 06:47 PM
Right but the charging lead shouldn't be grounding at all should it?
Old Jul 28, 2013 | 07:43 PM
Found it, the connection for the small wire to the alternator was damaged. No more drain.
Old Jul 28, 2013 | 07:45 PM
Yippee skippy!
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
97XD
Jun 12, 2007 09:23 AM
Brad S1
May 9, 2007 10:18 AM
S1disoinSC
Oct 29, 2006 01:08 PM
