Alternator question
Old Jan 19, 2017 | 02:05 PM
Luckyjayb's Avatar
Default Alternator question
does anybody know the size for a tap and die to re thread the shaft and nut to hold the pulley on a factory Bosch 130 amp alternator? Stripped mine...yea I know, I think I came up with some new curse words.
Old Jan 19, 2017 | 06:18 PM
LR03NJ's Avatar
Goog says its a 22mm nut for land rover discovery. Might be tough to die that one since it spins. Good luck
Old Jan 19, 2017 | 06:32 PM
Luckyjayb's Avatar
Yea I knew it was a 22mm nut. The darn threads are stripped on the nut and the shaft. Didn't know if there was a chance I can tap the bolt and put a die to the shaft and maybe save it and use it for a spare.
Old Jan 19, 2017 | 06:46 PM
LR03NJ's Avatar
I guess if you could hold the shaft from spinning you can die a tread size smaller and use plenty locktite red. If its tight enough, drill a hole through the pulley through the shaft and use a lock pin. Just a lot of effort there if you want to save it.
Old Jan 19, 2017 | 07:08 PM
Luckyjayb's Avatar
i got another on order, going with a 150 amp but if I can keep a back up, that much better just in case. You never know
Old Jan 19, 2017 | 09:34 PM
LR03NJ's Avatar
here are sime info regarding the 150amp alternator.
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
97XD
Jun 12, 2007 09:23 AM
Brad S1
May 9, 2007 10:18 AM
S1disoinSC
Oct 29, 2006 01:08 PM
