Alternator removal/bolts
Old May 13, 2010 | 10:43 PM
Guapo2004's Avatar
Default Alternator removal/bolts
trying to replace the alternator on my 2001 D2, but the two 13mm bolts are not cooperating.
It took a socket wrench, pipe and lots of persuasion to get the outside/top bolt free..but it did come out. But the inside/bottom bolt will have none of it, and just won't move (even after applying enough leverage that the socket head cracked)
Any trick/advise to getting this last bolt out is greatly welcomed.
In advance, thanks
Old May 13, 2010 | 11:17 PM
greenwade's Avatar
beer.... and a stronger socket. and beer
Old May 13, 2010 | 11:19 PM
Spencerfitch's Avatar
wow thats crazy, i removed two this weekend easy as heck.
Old May 13, 2010 | 11:20 PM
dont happen to have the belt attached still do ya?
Old May 14, 2010 | 01:00 AM
mwindth's Avatar
In advance, thanks
Lefty Lousy, Righty Tighty? And more beer...greenwade is right on.
Old May 14, 2010 | 07:05 AM
Guapo2004's Avatar
Thumbs down
thanks for the recommendation on the beer...prescribed to that solution when I was frustrated and logged on the computer to post this thread.
Belt is off...and yes I am cranking counter-clockwise....although I did give it 1 or 2 cranks to the right to see if I could unfreeze the bolt that way.
I did get the top bolt out (easier access and more room to crank on it) but it was tough...had to get alot of leverage on it.
Any other recommendations?
Old May 14, 2010 | 07:37 AM
d2luvr's Avatar
Heat - like a propane torch. Be careful of flammable bits.
Old May 14, 2010 | 07:39 AM
d2luvr's Avatar
I always use WD-40 to quench. The heat burns oxidation and the WD helps lube.
Old May 14, 2010 | 09:26 PM
Guapo2004's Avatar
Finally got it out this evening!!!
Lots & lots of heat, WD40, and a bigger stronger socket....and good old persuiasion...finally got that bolt to crack its seal, what a relief!
Now for some of that beer! thanks for the help
Old May 15, 2010 | 03:27 AM
d2luvr's Avatar
Glad to hear you are all fixed.
doomed
Jan 19, 2024 10:15 AM
sdhow
Jan 29, 2015 07:21 AM
marshman442
Oct 4, 2011 06:45 AM
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
