Alternator sprayed with hose blow-now toast?
Old Oct 8, 2017 | 08:29 PM
H Hill's Avatar
Default Alternator sprayed with hose blow-now toast?
'00 Disco II, 250K, engine rebuild 20K ago.
Friday after school, driving and had just turned into a shopping center, noticed the steering was very hard to turn and the battery light came on. Stopped, popped the hood and anticipated a broken belt, but found that the bottom hose assembly blew and sprayed coolant upward all over the front of the engine, small hole in the top of the "Y" in the hose.
Replaced the hose, filled with coolant, ready to follow the RAVE bleed procedure which I have done before. Started the engine and the battery light was still on. Looked at the alternator and the pulley was not turning the same speed as the belt. Thinking the belt was still slick with coolant, I cleaned the belt with some electonics spray cleaner, as I was concerned about spraying near the alternator. Restarted the engine, and now a scream or howl sounding like a failed bearing.
Thought and advice would be appreciated. Do I need to replace the alternator? Really had other plans during fall break other than working on my Rover.
Thanks!!
Old Oct 8, 2017 | 08:46 PM
Jwehking's Avatar
Belt still slipping?
Old Oct 8, 2017 | 09:25 PM
Bom2oo2's Avatar
Take belt off & spin alternator with hand, you will know if bearing is bad or not,
Old Oct 9, 2017 | 08:22 AM
Also check your belt routing to make sure it is correct
Old Oct 9, 2017 | 11:49 AM
OffroadFrance's Avatar
I can't see that a bit of coolant water would cause the alternator to expire, there maybe another issue which has been highlighted. Think of wading in 2' of water across a river and most alternators survive that.
Lord Wert
Jun 11, 2013 11:10 AM
Intellius
Jun 18, 2012 09:20 AM
flygirl92
Aug 9, 2011 06:14 AM
Eak69
Apr 4, 2010 11:52 AM
deeppockets
Jun 15, 2009 10:02 AM
