Am I installing this fuel filler grommet right?
Old Mar 12, 2016 | 11:05 AM
batard's Avatar
Default Am I installing this fuel filler grommet right?
I've been wrestling with the fuel filler neck for a while now, trying to install a new grommet after the old one turned to goo.
I kind of got it installed today, but I'm not 100% confident I'm doing this correctly. The grommet has a thin side and a thick side, and I'm not sure I have it oriented properly. At first I was putting the thin side toward the outside of the truck, and I had a hell of a time getting the neck to fit. Then I tried putting the thin side toward the back, and got the neck reasonably stuck in there. Could someone with an intact grommet check to see which orientation is correct?
Here are some pictures of what I'm dealing with: Imgur: The most awesome images on the Internet
Old Mar 12, 2016 | 05:48 PM
Charlie_V's Avatar
I have no idea but mine is gone so I'm subscribing.
Where did you get the new grommet?
Old Mar 13, 2016 | 04:03 AM
batard's Avatar
The part number is WLR000010. I got one at a local supplier, but it's also available at AB, etc. https://www.roverparts.com/Parts/WLR000010G
As you can see in the pic, it has a thin side and thick side. Still not sure if I've got it in right, but it's not moving, so perhaps it is.
Old Mar 13, 2016 | 09:54 AM
Charlie_V's Avatar
Yeah I wish I could answer just by looking but mine is completely gone. No trace. I appreciate the link! Sometimes I have a hard time finding parts simply because I don't know what theyre called.
I'm guessing this requires something more than just slipping the grommet over the end. Probably have to remove the filler neck tube. Ugh.
Old Mar 13, 2016 | 10:01 AM
batard's Avatar
You're lucky – mine turned into goo form and it got all over everything. The rubber these things are made of seems to be soluble in petroleum-based products (WD-40 wiped on it with a paper towel comes up black), which makes a WHOLE lot of sense given that it's near where you fill your gas tank.
I'm at the point of calling it done at this stage. There's nothing in the RAVE about its orientation, nor are there pictures/descriptions elsewhere online that I can find. My one piece of advice is you definitely have to seat the grommet to the body before pulling the filler neck through. You cannot put it on the neck and then seat it in the body.
Old Mar 13, 2016 | 10:13 AM
Charlie_V's Avatar
Dissolves in gas? That explains why they slowly disappear. What a stupid thing. I think mine dried up when I garaged my Disco for five years (no use during that time). Maybe it requires some gas to keep it pliable, but gas dissolves it too. That would fit my view of some of the parts on our Discos.
Mine has a piece of hose insulation taped around it to prevent rattling. You are the only other human being who knows that...
Old Feb 12, 2020 | 08:05 PM
Kevon Battersby's Avatar
Default Original positioning of grommet
Old Jun 14, 2021 | 01:47 PM
Sandman614's Avatar
Originally Posted by Kevon Battersby
Can you describe it or take the cap off? there's a thin side and a thick side to the grommet.
batard
Jun 6, 2019 05:23 PM
batard
Feb 15, 2016 03:33 AM
FlyingZebra34
Apr 23, 2012 07:47 AM
buick215
Jun 17, 2011 08:50 PM
B.Young
Apr 14, 2011 10:13 AM
