Amigo help
Old Feb 21, 2013 | 10:57 PM
pcossa's Avatar
3rd Gear
Default Amigo help
04 Disco. Three amigos and brake light are on. Mechanic says need to replace brake sensor and abs modulator based on codes. Two questions: 1. I need new brakes - could that be what is causing the lights? 2. Any harm in not doing the work and just rockin on? Disco drives and brakes fine.
Old Feb 22, 2013 | 12:44 AM
aarongregor's Avatar
Worn brakes will bring the boys out. Pull the sensor and clean it.
Old Feb 22, 2013 | 05:48 AM
hilltoppersx's Avatar
if you need brakes replace em. never buy a modulator they cost more then your truck. rebuild yours. it's easy and fun to do with a case of beer.
Old Feb 22, 2013 | 07:25 AM
russburcham's Avatar
What would be the best way to clean the sensors? brake cleaner? something milder?
thanks!
Old Feb 22, 2013 | 08:38 AM
I would not trust that mechanic at all, unless he can show you the scanner with the ABS fault codes, cause very few have a scanner capiable of reading the codes and to need to replace the module and speed sensors is too much.
Get a second option from a shop that will read the codes, right there in front of you. If the module is bad, they can be rebuilt for $120 in parts and 2 hours labor.
Jason_B
Feb 26, 2010 01:47 AM
bmccool21
Feb 9, 2010 08:41 AM
bullcrew
Dec 29, 2009 09:32 AM
Princess
Jul 4, 2009 12:24 PM
