Amigo says No Faults??
Old Sep 12, 2009 | 10:32 AM
RoverChum's Avatar
I'm curiours, if both of our lights are on, but your ABS doesn't work and mine does, could that indicate the source of two individual problems? For instance, I have ABS but no Hill Decent. Could that rule out the hubs and shuttle valve and point at a modulator? or other way around?
I've read other posts where owners took their truck to the dealership to have the brake system read by the LR/Factory reader (Testbook?) and the dealership still says "it could be a number of things". Am I wrong, or can the dealership pinpoint the problem? Mike?
Old Sep 12, 2009 | 10:47 AM
brooksa's Avatar
You are right, it could be a lot of different things from I've read also, but I had mine read a while back with a testbook and the fault was shuttle valve and right wheel sensor, I'm leaning towards my problem is with the shuttle valve. But I will test it again today and see how it acts and let you know.
Old Sep 12, 2009 | 09:03 PM
RoverChum's Avatar
Yeah, please post your findings.
Old Sep 22, 2009 | 02:05 PM
brooksa's Avatar
Well these are the faults that were read;
Any thoughts?
File Type: txt
Old Sep 22, 2009 | 03:43 PM
jycsalas's Avatar
As you can see every time you read the codes it pushed the older one out of the way. so go out and plug it in again and the ground fault wont show. WHICH MEANS you and I have more in common than we thought.
Old Sep 22, 2009 | 04:10 PM
brooksa's Avatar
I will read it again when I get home and post the reading,
Old Sep 22, 2009 | 05:32 PM
brooksa's Avatar
You were right, the grd code fault is no longer there;
File Type: txt
Old Sep 23, 2009 | 10:53 AM
jycsalas's Avatar
That's good! What next?
Old Sep 23, 2009 | 11:45 AM
brooksa's Avatar
Well I did the wiring check suggested by the TSB and by RSW website and , from what I can tell, everything is ok there. So now I guess I'm moving forward to the Shuttle Valve Kit and if that doesn't work then I guess on the Modulator itself. I know AB has a SV kit but I also found one from Falcon Works in Arizona, I spoke to him yesterday and his thoughts from my description of what was going the SV kit should take care of the Amigo's, but there is a chance it will not.
I guess that is where I will start
Old Dec 21, 2010 | 06:01 PM
RoverChum's Avatar
JYCsalas... THANK YOU!!!
2 months ago I did your 3 Amigos "ABS mod" from your write-up and I have been Amigo free since.
Everything works perfectly and I'm getting used to the truck not chiming with the dash lighting up.
Everyone with the Amigos should try this fix.
Thanks again.
For those who need it, use the link below.
http://www.landroverclubvi.com/abs-mod.html
mgabriel
Mar 30, 2011 12:31 PM
TYoung
Freelander
Aug 17, 2010 04:19 AM
Princess
Jul 4, 2009 12:24 PM
lipadj46
Jun 12, 2009 12:04 PM
