Amsoil Oil Change?
Old May 28, 2007 | 03:00 PM
discobob's Avatar
Default Amsoil Oil Change?
Anyone using it?
Old May 28, 2007 | 03:17 PM
Default RE: Amsoil Oil Change?
I know some people that are using it, what is your question?
Mike
Old May 28, 2007 | 03:30 PM
discobob's Avatar
Good stuff?
Old May 28, 2007 | 04:06 PM
Can you be a little more specific with your questions? What are you wanting to do and to what?
Mike
Old May 28, 2007 | 06:52 PM
discobob's Avatar
2000 Disco.......82,000 miles. Runs well. Was wondering if Amsoil is worth the expense, or is it just slick (no pun intended) marketing?
Also, anyone know any good alternatives to the uber expensive safari roof rack? Have seen some that look a little more industrial.
Any good sources?
Old May 28, 2007 | 07:23 PM
Newfoundlandrover's Avatar
DiscoBob,
I'm my experience,any good quality synthetic oil will serve your discovery well.Some brands are more expensive than others,but a lot of it is just hype.Any of the top brand synthetics are good.The main reason for running a synthetic in the first place is to keep the engine running a little cooler by reducing friction,any of the top brands will do that for you.10w40 is a good universal weight to start with.Discovery V8's get hot fast and the main killer of these engines is overheating.Whatever you can do to keep this engine running cooler is money well spent,be it top quality synthetic oil , running a premium coolant or what have you.As for your roof rack question,Rovers North and Atlantic british both carry good quality aftermarket racks in a couple of different styles.
Old May 28, 2007 | 07:45 PM
Even with the better quality synthetic oils, you must chnage the fluid more frequently, usually by at least 5000 miles, Rover engines run way to rich and contaminate the oil with fuel.
As for the roof rack, you are out of luck for now, Saftey device is no linger making them nor is Rovers North.
Mike
Old May 29, 2007 | 11:13 AM
Aquaholic's Avatar
The oils that are truly better have the ability to not turn acidic over time better than other oils - AMSoil is very good at this.
Problem is our trucks put too much gas in the oil for this to ever become a concern.
You can get your oil tested for about $20 - do this every few oil changes and you'll learn a lot.
Old May 29, 2007 | 12:24 PM
okdiscoguy's Avatar
Amsoil is a good oil, but it is expensive. I would recommend that you use Mobile 1 full synthetic. Royal Purple and Amsoil out perform other oils, but since they cost so much more, it isn't worth it. You can't get the extended drains out of these oils, so it makes the cost an issue. Mobile 1 is a good oil.
FYI, last month Corvette Enthusiast Magazine did an independant test to see if RP was better than Mobile 1. RP beat Mobile 1 by 3 hp and 5 Ft-lbs of torque
collin Barrows
Aug 28, 2011 07:13 AM
chad420
Oct 26, 2009 09:38 AM
chad420
Jul 20, 2009 09:45 PM
zerochills
Jan 10, 2008 12:01 PM
DEEBEE060
Aug 6, 2007 10:17 AM
