annoying tapping or ticking sound when idle
Old Oct 16, 2008 | 07:51 AM
marlymarl's Avatar
Default annoying tapping or ticking sound when idle
Hi
I have a 2000 Disco with 66,000 miles on it. Just did an induction cleaning. Had an annoying tapping or ticking sound before. After the induction cleaning I still have it but is seams to be trying to go away. What do you recommend to stop this?
Old Oct 16, 2008 | 07:53 AM
jmrivera's Avatar
Default RE: annoying tapping or ticking sound when idle
Does the sound increase in frequency when you rev the engine?
Old Oct 16, 2008 | 07:57 AM
marlymarl's Avatar
it does not make any tapping or ticking sound when the pedal is on the gas. Only when sitting at a light or in a park position.
Old Oct 16, 2008 | 02:38 PM
Willie 00D2's Avatar
Mine does that too. Sounds like lifters to me.My 50 year old tractor engine is quieter then my rover.
Willie
Old Oct 16, 2008 | 03:47 PM
Switzer's Avatar
Run 0w30 Mobil 1. After Seafoam, ATF flush, and switching to 0w30 synthetic the ticking went away.
Cheers,
Pete
Old Oct 16, 2008 | 05:12 PM
Take a short piece of rubber hose and stick one end to your ear, the other end against the engine listening for the noise, move around and pin point where it is coming from.
Old Oct 16, 2008 | 06:52 PM
Is 0w30 ok for an engine with 145,000 miles?
Thank you,
Willie
Old Oct 16, 2008 | 07:02 PM
Depends on where you live Willie. It might be fine for the winter time, depending on where you live.
0W-30 will be to thin if it only gets down into the 30's at night.
If it gets down below 20 and stays colder, like in the 30's during the day then that oil would be fine.
If your idea of cold is 40, then go away.
You will need a thicker oil for the winter.
Old Oct 16, 2008 | 07:21 PM
jkid's Avatar
ORIGINAL: Willie 00D2
Thank you,
Willie
It's still a 30 weight oil once it reaches operating temperature, which Rover does recommend. It just stays a little less viscous at the same temp than a 5W or 10W when 'cold', which I think is always good for any cold start-ups no matter what the temp. People seem to use a 30 wt., a 40 or even 50 wt. oil with no problems. I have some M1 0W-40 I'll be putting in next, that sounds like a happy medium.
94svt50
Apr 21, 2011 04:43 PM
kae
Mar 31, 2011 10:19 PM
Analogkid
Jan 19, 2011 11:35 AM
Aj6543
Nov 8, 2009 06:44 PM
mr.47
Mar 27, 2007 02:45 PM
