another 03 engine tick
Old 08-11-2010 | 02:51 PM
David A's Avatar
Put in BG44k and filled it up...we will see what happens.
Old 08-11-2010 | 04:41 PM
bulldozer32's Avatar
i've got the same thing happening on my 04 truck.
Old 08-16-2010 | 06:40 PM
David A's Avatar
Finally got the oil pressure tested..Although he did not test it while cold so the readings are only hot.
8@ idle
40@2k
Thoughts?
Old 08-16-2010 | 08:39 PM
8psi at idle is to low, the oil light comes on at or below 8psi.
Old 08-16-2010 | 09:18 PM
David A's Avatar
Thanks for info....Think that low enough to make it tick.
Old 08-17-2010 | 10:22 AM
Disco C's Avatar
yes. drop the oil pan and check the oil intake screen.
Old 08-17-2010 | 10:32 AM
Bundu's Avatar
Banned
That's way too low at idle, sure it will cause it to tick and be noisy.
Old 08-18-2010 | 03:14 PM
David A's Avatar
In the shop getting the pump changed out. Hope this fixes the ticking issue.....
Old 08-18-2010 | 03:30 PM
Bundu's Avatar
Banned
Just the gears or the whole $600 front cover?
Old 08-18-2010 | 06:40 PM
David A's Avatar
Front cover is being replaced as well as the timing chain water pump and a new belt. Anything else you guys can think of while he has the front apart?
Quick Reply: another 03 engine tick
