Another Amigos Question, Maybe!!
Old Aug 29, 2009 | 06:47 PM
vmann7's Avatar
Default Another Amigos Question, Maybe!!
Just took a quick run to the store and when stopping at the end of the block what I initially assumed was the three amigos came on with a chime. They stayed on till I turned it off at the store and when restarted, only the abs light came back on, and then went away a block later.
After searching the forum it dosent look like a classic three amigos, the lights were the traction control, ABS and emergency brake.
I checked the fluid looks OK but due for a flush in the fall and the pads were all replaced less than 3K ago. The rotors will need replacing next time the pads are due though.
From my searching is it possible the fluid indicated low from the stop due to the rotors being thinner? I read thin pads can give you this condition.
Thanks.
2004 DII with 66K
contacthansel
Jun 18, 2010 09:52 AM
Timpala`
Feb 2, 2010 05:44 PM
bmayer01
Feb 10, 2008 08:12 PM
S1disoinSC
Oct 29, 2006 01:08 PM
kend500
May 19, 2006 12:28 PM
