another Amigos & shuttle valve post
Old Nov 9, 2012 | 03:57 PM
DiscoMeadows's Avatar
Default another Amigos & shuttle valve post
I have an ABS amigo scanner and pulled my ABS code: 114 Shuttle Valve Electric Failure. I have read the posts about the fix, I can do that no problem (Thanks Josh!).
However, when my lights come on when pressing the brakes (sometimes), it feels like a momentary engaging of the ABS system. Is my sensor actually telling me I have a problem, or is it just a bad sensor? Do I need to rebuild the shuttle valves?
If I do the ABS Modulator fix without repairing the shuttle valves could I have a problem with the modulator but no warning light, since the sensor is bypassed?
It would be nice to know before I take things apart, so that I have the right parts for the repair.
Thanks!
Old Nov 9, 2012 | 04:06 PM
With your mileage and if you plan on keeping that Disco, also replace the shuttle valve and o-ring set then do a full 2 quarts DOT 4 brake flush.
Old Nov 9, 2012 | 06:03 PM
Bkreutz's Avatar
Thanks!
The sensor is not being bypassed, all that is being bypassed is the internal wiring of the shuttle switches to the wiring harness.
Old Nov 13, 2012 | 06:24 PM
Never underestimate how hard this job is, while being helped by a 2 year-old!
bosshogt
Feb 2, 2012 06:52 PM
azoverlander
Mar 12, 2011 02:16 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
meltdowndave
Dec 9, 2009 08:49 PM
wesk
Feb 17, 2008 10:22 PM
