Another Crank position sensor thread
Old Aug 21, 2014 | 04:48 PM
vette427sbc's Avatar
Default Another Crank position sensor thread
2004, 118K miles. Drove it home no CEL, parked it, came back 1 hr later, cranks but will not start. Everything Ive read says crank position sensor. Anything else I should be checking to confirm this? Autozone sensor ok to use?
Old Aug 21, 2014 | 05:41 PM
DustyLBottoms's Avatar
Sounds like it. I used the Advance Auto sensor with no issues. If you wanna save yourself some heartache take my lead:
https://landroverforums.com/forum/di...e2/#post443936
Old Aug 21, 2014 | 05:59 PM
Good thinking! Thanks for the reply!
Old Aug 21, 2014 | 06:12 PM
dr. mordo's Avatar
The first thing you always check is the fuel pump relay. It has very similar symptoms to the CKS.
Swap it with the wiper relay next to it, then try to crank the truck. Takes 5 seconds.
Old Aug 22, 2014 | 06:53 AM
drowssap's Avatar
if you put a scanner on the track and crank it does it read 0 for RPM,
if so probably a CPS
Old Aug 23, 2014 | 03:48 PM
kfx4001442's Avatar
^ This WORKS! Helped me confirm my problem!
Old Aug 23, 2014 | 11:34 PM
Im going to try this in the morning...
Im stumped now though.
Swapped the relays to make sure it wasnt the fuel pump relay. No difference. Replaced the CPS with a bosch unit today. Started up and drove fine no codes and then just shut down while driving. Still no CEL or even pending codes. It will start intermittently if I let it sit but wont run for more than 2-3 miles before dying and giving me the crank, no start symptom again.
Old Aug 24, 2014 | 01:58 PM
jafir's Avatar
You might put your hand up near where the exhaust manifold meets the y-pipe, while it's still cool enough to do so, and check for exhaust escaping at the flange. Someone recently suggested that an exhaust leak there cooks the crank sensor and could be part of these failures. Seems like an interesting and plausible idea.
Old Aug 24, 2014 | 02:00 PM
jafir's Avatar
Im going to try this in the morning... Im stumped now though. Swapped the relays to make sure it wasnt the fuel pump relay. No difference. Replaced the CPS with a bosch unit today. Started up and drove fine no codes and then just shut down while driving. Still no CEL or even pending codes. It will start intermittently if I let it sit but wont run for more than 2-3 miles before dying and giving me the crank, no start symptom again.
Fuse box would be my next guess if the new sensor isn't fixing it.
Old Aug 25, 2014 | 12:06 AM
kfx4001442's Avatar
I had the EXACT same issue after replacing my CPS. It ended up being a loose connection where the CPS connector plugs up. You really have to SQUEEZE those two together tight. I felt a click when doing so and its been fine ever since!
