Another noise...
I suspect this is coming from the transmission/drivetrain...
First, I have experienced altered shift points since installing Mobil 1 Synthetic ATF. Used about about 10qts on the install and pulled the check plug a week later to make sure it was full and it spewed a steady stream of ATF, filled back up and all is good with the exception of these shift points. Has anyone else experienced these symptoms when using a non conventional atf?
Now the noise. Only happens when OFF the gas at lower speeds (35-5mph), instantly goes away when load is put on the drivetrain. Interestingly, if I shift into 1st no noise on deceleration. When put into 2nd, 3rd or drive, noise is back. I think I have narrowed it down to second and 3rd gear making an almost flapping/tapping type sound upon deceleration. I do plan on changing the ATF out this week to a conventional Dex3 to see if it helps even though the M1 has been in there for 15k noise free miles.
Anyone suspect any other components causing this noise or experienced similar issues?
Very similar issues as this guy:https://landroverforums.com/forum/di...problem-36387/
I don't suspect it's the front prop shaft since no noise in first gear.
on
Also, not sure you put 10 quarts of ATF in, 5.5 to 6 is about all you can put in with out draining the torque convertor.
Also sounds like you may have not filled or checked the fluid level correctly if you are pulling the fill plug and having ATF flow all over your arm, did you check the level with the engine running, if not and you spilled a lot of fluid, you are now short on fluid and need to refill while the engine is running and the tranny is in park.
I bought 2 6 packs of the M1 and have 2 quarts left over. I did follow the procedure that is on here... Drain, fill, start car, move through gears slowly a few times, shut off, top off, restart, shift through gear and fill till needed etc. I even drove around a week and rechecked the level with the car running to make sure the tranny was full (it was), lost a a quart in the process so I guess that could explain why I used 9-10 qts, I was very thorough and don't suspect installer error.
At this point, it sounds like it could be a few things....
Alright guys, bringing another thread back from the dead as I continue to have these issues.
The shift points have not changed after a swap form M1 Syn ATF to a conventional Dex3 has got me annoyed but not concerned as I don't think transmission failure is likely as a result of this symptom. Any feedback is welcome though![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
Now for this noise!!!!!!! It's got me so f'ing pissed off... I got both drive shafts rebuilt, greased and balanced per the write up. No change in the noise at all. Upon further driving, I can actually feel the tapping/flapping noise on the actual gear lever and console where P R N D 3 2 1 is, nowhere else. It's apparent to me now it's coming from somewhere in the transmission. Could it be some solenoid just going nuts? Anyone heard of this issue? I suppose I could pull the center console out to get closer to the problem. Still haven't been able to get it to a buddies and put it in the air and run it.
So... Upon further searching I came across a few threads that have had similar problems citing the transfer case being responsible for the noise. I put this to the test.
I engaged the transfer case into the low setting, no noise to speak of. Switched back to high and the noise is still there but seemed to quiet down a bit after the changing around of the ratios.
Any thoughts?
Any thoughts?
Watch Land Rover Discovery II Transfer case gear spin - YouTube. Note the point when the gears stop, when brake is on. So is you noise also at idle, or just while motivatin' over the hill? And tapping - could that be ticking, as in flex plate cracked?
I'll say again, I can feel the actual vibration of the flapping/ticking on the gear selector. I wonder if taking apart the center console will help?
I want to add, I took the truck out for a spin after watching this video and beginning to think we are on the right track. So on deceleration putting the truck into neutral the noise does not go away. Thus, the tranny being ruled out (thank god)... Hell, I could be experiencing the same issue in that video but just can't hear it at lower speeds or the problem hasn't quite reached a high level of noise yet.
I need to get the car in the air, wheels off the ground and get underneath to see what the heel is going on. If I am indeed experiencing this, what is the fix? New transfer case? Is just the center diff? I suppose the flex plate could be the issue too... I'm doing the oil pump in the coming weeks and will inspect that part.
