Another noise...
Savannah, this morning I went out with my old lady to listen to the car being fired up... The video is showing exactly my symptoms. I just could not hear it inside the car, even with the window open. Car was in park, transfer case in High. It was rattling around like crazy! What are my options if my transfer case is bad?
1. Try a stiffer fluid, like the 85W150, which should quiet a noisy case.
2. If still noise; Drain. Remove inspection plate (will have to reseal with RTV). Inspect - what is found inside may indicate problem (trash, pieces of a seal, broken gear teeth). Seems like I had to fiddle with a heat shield to get at some of the inspection plate bolts.
3. Plenty of posts about guys pulling TC, replacing seals, etc., or buying a used one. Keep in mind that most Disco's end up in scrap yard due to overheated engine, so a used case is reasonable.
Just tagging, because I have been experiencing the same "deceleration" noise for a little while myself and it has been driving me nuts. I haven't checked the transfer case yet. I'd say it sounds more like a knocking/rapping noise than a tick to my ear.
I am interested in your findings.
-Ben
-Ben
-Ben
-Ben
Starting a new thread... Transfer case is confirmed being the issue. Follow here:https://landroverforums.com/forum/di...88/#post311279
