...Another Oil Leak
Old Dec 19, 2011 | 08:20 PM
Are you having to add oil every other day? Is the EPA parked in front of your house with HAZMAT suits and citation book?
Dont worry about it.
Or you can buy this, follow the directions and be done with it.
Buy White Shepherd Oil Stop Leak 49499 at Advance Auto Parts
Old Dec 19, 2011 | 09:21 PM
EstorilM's Avatar
And pretty hard for the front seal to get oil high up on the engine....
Right.
Well in case you didn't notice, the first picture is hardly "high up" and by your logic, I could simply say the same thing - pretty tough for valve cover gasket leak seepage to cover the oil pan.
Anyways, every DII I've seen leaks around the valve cover area - so that's not the variable here - if it's ending up down there, and ESPECIALLY if its dripping onto the ground / diff / etc. I'd take the others' advice and clean her up then check in a few days.
Mine was a PITA, when raining the parking lot would look like a freaking oil slick,
and it was staining the driveway. FWIW it was never enough to require topping off somehow - but I also didn't really let it slide for that long!
Old Dec 19, 2011 | 09:52 PM
boris_gti's Avatar
My engine look the same few months ago. I got fed up with guessing and changed all gaskets, seals, water pump, oil pump, pulleys, belt, engine cover, timing chain, gears, etc. Turned out to be the best thing I could have done.
Love the truck since then! 10 times more dependable!
Old Dec 19, 2011 | 10:26 PM
Agreed, Murphys's Law is a multi-volume set. My Mercedes can out leak the Disco by volume, but not by number of locations.... I park over sand, in the future they will think it is the southern version of the Canadian tar sands...
Old Dec 19, 2011 | 11:19 PM
Snafu / Disco Fries's Avatar
I was having a hard time finding orientation on the 2nd pic, so not sure. To me, it looks like the rear valve cover gaskets are leaking. As mentioned, be sure to loosen a bit and then torque to specs. Mine started to leak a few months ago. I cleaned it off, did that and it has been oil free since.
The front seal could be causing the drip towards the front (if that is what I was looking at). I would get a small oil spot every so often from in back by the oil filter. When I had it apart for the water pump, I was able to see it from there. Very minor. I wish I had the gaskets while I was in there so I could have handled it then but didn't.
cmpt
Nov 28, 2012 08:30 PM
djblackrain
Sep 13, 2012 10:12 PM
Hyakku
Sep 17, 2010 08:49 PM
JAC
Oct 2, 2009 09:41 AM
rgrizzard
Mar 6, 2008 10:16 AM
