Another one with high idle
Old Oct 22, 2009 | 06:53 PM
leadfoot's Avatar
Default Another one with high idle
Hello guys.
D I 1997, 150K miles. No codes. I was having problems starting and after a quick check determined that my fuel pressure was too low and got a new fuel pump. After I replaced the fuel pump the car run great for about a week. Then started acting up. When I stopped the RPM would go very low and sometimes it would even die. I read here to check for vacuum leaks. I checked and found no leaks, while checking I did unplugged the stepper motor and cleaned the contacts. Drove around the block and the same problem, low idle when I stopped. Here is where it gets spooky. I went to bed. Next day started the car and the RPM went to 2k. From then on, it stays at 2K at idle until it warms up and then lowers to about 1200 RPM.
What is going on? Why went from too low idle to too high? There are no codes, and other than the high idle it runs like a champ.
Thanks
Old Oct 22, 2009 | 07:05 PM
Your original problem is a bad fuel temp sensor.
You need to clean your stepper motor and the port that it goes into, remove it, clean it with carb cleaner, the port it goes into too.
Use your wifes toothbrush if you need to to clean it well.
All the holes inside need to be obstruction free.
Just make sure you put it back in the correct way and do NOT turn the plunger at all.
Do all of this with the key off.
Old Oct 23, 2009 | 10:07 AM
Also, since you have replaced your fuel pump, you should also replace the fuel filter and check and replace any vacuum hoses that are cracked/leaking or collapsed.
wick_60010
Nov 22, 2017 04:25 AM
omarica7
Mar 11, 2014 08:12 AM
hankwhite
Oct 24, 2013 11:25 AM
ljdiscovery
May 16, 2010 02:23 PM
Brad S1
Jul 7, 2006 02:13 AM
