Another seafoam + oil question??
Old Dec 31, 2007 | 04:18 PM
hollis's Avatar
Default Another seafoam + oil question??
Hey all.. I know I have seen the post about using seafoam in the crank case but there are so many I cannot find it!! I wanted to use a can to clean out my engine before I do an oil change... any suggentions?? I do know about the ATF flush which I did on another vehicle but wanted to know ther difference. Thanks in advance!
Old Dec 31, 2007 | 04:33 PM
okdiscoguy's Avatar
Default RE: Another seafoam + oil question??
Use a can of gunk flush if you want to flush. Seafoam does not do as well in the crankcase. An ATF flush would be the best for starters...
Old Dec 31, 2007 | 04:46 PM
hollis's Avatar
I have a tapping valve. Would you still do a ATF flush??
Old Dec 31, 2007 | 05:47 PM
What year and how many miles on your truck?
Old Dec 31, 2007 | 07:46 PM
hollis's Avatar
02 with 90,000
Old Dec 31, 2007 | 09:13 PM
the flush might solve the lifter noise. could be a clogged oil inlet on one of your lifters.
Old Jan 1, 2008 | 12:43 PM
hollis's Avatar
and a flush would solve that? Or at least help?
Old Jan 1, 2008 | 03:21 PM
jmt's Avatar
jmt
The Gunk flush solved mine for me. I plan on doing them every 10k miles.
Old Jan 1, 2008 | 05:22 PM
If you use full synthetic oil it will help keep your engine clean. It has more detergants than conventinal oil.
It will also clean a engine over time.
nashville_disco
Feb 15, 2009 04:42 PM
Disco Fuego
Feb 4, 2009 11:18 PM
AK Rover
Aug 20, 2008 10:29 PM
jdelp
Jun 21, 2007 04:16 PM
BMartin318
Nov 20, 2006 11:16 AM
